2012 DODGE Challenger SRT8
GOOD Day! Has someone seen this before? I have a 2012 Challenger SRT8 68K miles. Coolant leaking just under the upper radiator hose. The t-stat housing does not seem to be the culprit. Thanx.
996092
996093
the only things up that high on the engine:
heater coolant pipes
  • there's one on backside of timing cover (o-ring seal)
  • another one that comes around to water pump (o-ring seal)
Coolant temp sensor - usually on driver's side
Thermostat housing
to remove the coolant pipes, you'd remove the intake, pipes have a bolt securing bracket to back of head and pipe pulls straight out to service o-ring
Thank you for the information Hal H. I'll have to remove the intake. I have a tiny scope camera and still couldn't see anything with it. Its deff NOT coming from the upper hose/tstat however.
Frustrating. I cant find a source. From what I can see it looks like coolant is originating from the gasket between the water pump and engine??.
Thermostat housing
I had the exact same leak and the water pump is considered part of the power train Warranty covered my water pump and they gave me a rental car to drive for a day or two.
2011 srt8 The leak was indeed the water pump. replaced it, the lower hose and t-stat. all is good!
Thanks for following through on the conclusion of your issues. It is now a valuable resource vs. a lingering mystery.
