1 - 1 of 1 Posts
Dodge Challenger
I'm trying to see if I might have a problem if I replace the driving lights assemblies (fog lights) on my 2014 R/T that only use a low watt bulb (28watt, I think}, with the driving lights from an earlier Challenger that used a 55 or higher Watt bulb???? I've looked at the earlier light assemblies and don't see any difference between the two except for the higher wattage bulbs and wiring, but will the lighting circuit handle the extra amps draw?? It's not like I can change the wire size and fuse to handle the higher wattage unless I do the whole circuit with a relay and fuse. Any help is appreciated
1 - 1 of 1 Posts
