1 - 3 of 3 Posts
This maybe too early, was wondering if someone has started to or looked into fitting the 2011 auto temp controls into pre 2011's.
Wondering if it will just be the control panel with a temp sensor (which is used by the dash sensor on other models)?
And/or if it will require the whole HVAC unit?
Just dreaming..........for now.
Challenger atc
Wait a little longer and they will start appearing in the salvage yards.
If you have automatic headlights you should already have the light and temperature sensor in the dash. The next questions will be is everything controlled by the atc controller and are the wiring harness plugs the same. I know from personal experience that the 300 and charger cannot be switched because the wiring harness is conpletely different.
1 - 3 of 3 Posts
