just as the subject says,,, can you post pics and details about fit?
10.5 in the rear fit perfect with 25mm offset. 20mm will probably rub on the outer fender as it pushes it outward, depending on the tire width.
The front, 9.0 wheel with 20mm offset fit perfect. 10.5 wheel up front will not work without rubbing.
ok... I guess im looking for max. you can go on the front?
yes ive read ppl do 10 inch wide with 5mm spacers,,, but thats on a orig. 18 offset. ill play with the offset calculator. Im guessing if that works I need to find out if a 10inch wheel with a 25 offset fits on the front?
