1 - 20 of 42 Posts
Seems this is fake as it looks to be two button.. Not just one button
Don't have to read about it. I am living it.
My 2018 Hellcat's paddle +shifter can trigger a downshift about one in 10 or 12 shifts, but sometimes even back to back. The other thing it can do is fail to trigger an upshift. This is most noticeable if it happens in trying to go from 1st to 2nd. One's mind and body is primed for the upshift but it does't happen.
But I have noticed it in trying to shift from other gears from 2nd on up to 7th into the next higher gear. And I do not see the "shift not permitted blah blah blah" warning message appear because I'm trying to shift to a higher gear at too low an RPM.
The downshift when an upshift was intended is the worst though. That's starting to really bug me. I'm loathe to take the car in because I'm thinking the tech won't be able to reproduce the problem. However, I'm sure if one wants to ride with me I can duplicate the problem. In fact I may insist on this as I want to be sure the behavior is demonstrated and get the ball rolling to get this fixed.
One major factor in my decision to get the A8 vs. the manual was because of the paddle shift feature. I use it often. But it is severely impacting my enjoyment of the vehicle that with this +shifter problem I can't use the paddle shifters except in the most cautious manner to allow for the possibility of a downshift at any time I pull back on the +shifter.
The transmission shift lever is not very well located to use it. To use it requires a bit of an awkward position of my arm that it is very rare I even use the lever unless the wheel is turned so far I can't know which paddle is the + or the - shifter.
Hi Rockster,
We sorry to hear about this. We certainly understand how frustrating this may be. Please feel free to let us know if you decide to address this with your dealer and we will gladly assist you during that process.
Lydia
Dodge Social Care Specialist
Hi Rockster,
Lydia
Hi Lydia. Thanks for the offer.
Getting closer to taking the car in. At a stop light last night I was shifting from 1st to 2nd and then trying to shift up to 3rd which of course the transmission refused to do. Then I'd use the -paddle to shift back to 1st. At one point when I pulled the + paddle in 2nd to try to go to 3rd the transmission went back to 1st. Then when the light changed to green and I took off in 1st and shifted to 2nd with no problem then after a bit more acceleration in 2nd I went for 3rd but the transmission went back to 1st. Because I'm aware of this possibility I didn't take RPMs too high before shifting from 2nd to 3rd but the tach still jumped up to around 4K when the transmission went to 1st. Very disconcerting.
Remembered last night I have a data logger connected to the OBD2 port which captures/logs vehicle and engine telemetry and I will pull out some logged data and make hard copy so I can show the dealer what is going on without having to reproduce the behavior, although it is not hard to reproduce. Just use the +paddle to shift.
What I was sort of waiting for was for someone else to post he had taken his car in for this and gotten it fixed so I would know there was a fix and what it entailed.
It looks like I might be the first, though, as this behavior really takes the fun out of driving the car.
When I take the car in I'll be in touch.
Marc (Rockster)
Rockster I have the same exact car as yours, only difference is color and probably miles, cause I know you've had yours several months before me...I haven't had any shift issues thus far, but something new has popped up lately, that would be the 1-2 shift in manual track mode shifts so hard it changes the radio station upon the shift which sucks cause that's my normal custom mode of driving..I don't like it in auto cause it holds 3rd to long (hangy and normal) at light throttle..with that said, what's your miles? I'm approaching 1500..maybe it's an age thing maybe a bug-a-boo in the software, hopefully as earlier mentioned your issue is with the paddle(s), please keep us posted
There have been threads here and elsewhere where people reported that changing the whole paddle assy fixed the issue, but also those who say it did, and then came back. So perhaps those that reported success, just never came back to report it reoccurred. People have also done the same with a flash, reported a fix/reported it reoccurred.
https://www.motor1.com/news/339854/charger-challenger-paddle-shifter-problems/
This must be an issue with v8? My car has around 7800 miles..2018. I don't use paddle shifting often unless I'm going fast or just feel the need to use the manual mode
I had this happen once in the Scat Pack. I used the paddles nearly all the time, so frequency wasn't there...the "I wish I wore my brown pants" moment sure was when it happened.
Fingers crossed this HC avoids that nonsense.
Discussion Starter #12
I just dont understand this. One would think that the paddle shifters use two buttons instead of just one.
Mine was one of the instances where changing the paddles, fixed the issue on my 2015 SRT. I went for several months with no re-occurrence before the car was totaled. Before they were swapped out, it happened all the time.
No issues at all with the 2016.
My Hellcat is a 2018 bought Feb. 17, 2018. Currently it has just under 13,000 miles, but if I drive it to work today and I think I will it will then have just over 13,000 miles.
Early on when I used the auto in manual mode I used the shift lever. But the lever is not well positioned for this manual shifting and in some form of mild frustration with this I began to use the paddles, primarily the up shift paddle. I found it easier and better to just let the transmission handle down shifts except in the rare times a downshift was needed to say pass a slower vehicle or to when I could just enjoy the acceleration.
I probably used the paddles at around 1500 miles but just as probably not very much. I didn't really get frisky with the car until the odometer hit 2K miles. At first what I recall seemed to be the problem was occasionally an up shift was not made when I pulled the +paddle. There was no message about the shift not allowed due to speed. The shift just didn't happen.
The behavior was so unexpected that I thought at first the fault was with me, that I failed to operate the paddle correctly.
But with experience and experimentation there doesn't seem to be any way to operate the paddle incorrectly. I tried operating the paddle in such a way to see if there was a way to possibly vary or even interfere with its operation in some way but mechanically the paddle when pulled just feels the same no matter how I try to affect it. Tugging back hard, or soft, pressing at some point down the paddle, as close the wheel as possible, off center, and so on, nothing I could do appeared to have any effect. Actually this is what I would expect of the paddle's design. That nothing the driver could do would affect either paddle's behavior, fail to trigger an up shift as long as the shift was not denied due to insufficient vehicle speed or in the case of a down shift would result in an engine over speed condition.
Might add that the position of the steering wheel doesn't seem to play a role either. Straight ahead or turned even turned slightly or closer to full lock the down shift instead of an up shift can occur and does occur at about the same frequency.
After some time though the "condition" worsened and while occasionally an up shift fails to happen more often and of course much more noticeable and disconcerting is rather than an up shift a downshift occurs.
The behavior appears to be independent of any other factors other than maybe it is less likely to happen when it is cold. While it doesn't get that cold here this winter, late last year, and earlier this year, it has been down into the 30's at night and often not getting to even 60F during the day. There was a spell of maybe 2+ months when the behavior was rare.
But with warmer weather now with overnight temperatures in the 40s or low 50s and day time temperatures breaking 70F the behavior is much more frequent. This suggests the temperature of the switch might (might) be a factor but it could be that the switch is just deteriorating and getting worse and temperature doesn't play any role.
Engine and transmission temperature do not seem to be a factor.
I think I have had sport mode possibly even track mode active at least once or twice but I have not exhaustively tested these modes or tried to use any of the features they offer.
Doesn't feel like a software issue. Really software only comes into play to upon a signaled up shift to deny this if the vehicle speed is too low for the gear being selected or in the case of a downshift being signaled to deny this if the shift would result in too high an engine speed.
The only software update my car is due for is the one to address the cruise control issue.
Guess my next step is to visit the dealer service department and see if there is a fix for this. I'm very reluctant to book the car in for this if there is not as it is inconvenient to me, disruptive to my schedule, to bring a car in. IOWs, to bring the car in for a problem for which nothing (at this time) can be done is just a big waste of my time.
Thought I'd update this spurious downshift when pulling the +paddle matter...
The short version is I contacted Dodge Customer Care and reported the behavior. After a few days the customer care rep got back to me. This is what she had to say:
"I was advised that this is a normal operation but you are to pull the paddle shifter for a longer period of time (1 sec or longer) to help mitigate this concern."
At first I was rather upset with this response as I felt how the paddle was operated should have no bearing on the shifting behavior.
But I came upon another post in which the poster supplied a copy of a letter, some official document, from Dodge offering more detail on this behavior. I don't have a copy of the document to post and the post is in another forum, but the info supplied lends considerable credence to the customer care's response.
So after thinking about this advice for a while last evening after work walking out to the car I decided upon a +paddle technique that would result in the paddle being held longer.
Now when I pull the +paddle instead of a quick flick I hold it until I feel the transmission shift. This results in the paddle being held longer, maybe not 1 second but closer to this than the quick flick technique obviously.
So last night on my 30 mile drive home I worked that +paddle nearly to death using this new technique and not one spurious down shift or ignored shift.
While it is too early to say this is the solution it has good promise of being the solution. And to me the slightly longer +paddle hold time is not inconvenient or onerous. The transmission shifts as quickly as always and if the shift is in the right direction, always, the extra hold time is well worth it.
My advice to those owners who are experiencing this spurious down shift from the +paddle adapt the above technique or one of your own but one that results in a longer (slightly longer) and consistently longer +paddle hold time and see if the spurious down shift behavior goes away.
Oh, I found that if I continue to hold the +paddle down after the shift the transmission does not continue to up shift. OTOH, holding the -paddle down will have the transmission downshifting until it can go no lower in gear selection without over reving the engine.
I have really enjoyed my 2013 SRT8 and the paddle shifters are a big part of that. I've had the car 2 yrs, I bought it with 7500 miles on it, now it has 21000. Two days ago the + paddle started misbehaving. I had to hit it 5 times once to get a 1-2 shift. All gears would act up, sometimes working ok, others not at all. Using the shifter the car worked perfectly. I never experianced the down shift with the up paddle problem. My enjoyment of driving it dropped a bunch that day. I read the thread about this problem linked earlier on this thread where the Dodge cares person said to hold the paddle for a second. That just shifts it into drive. Today I drove the car in auto then started shifting using the shifter a few times, then going to the paddles and it shifted fine at that point on. Hope it continues like this because I really like the paddles.
Well, an update is while the spurious down shift from the +paddle stayed away for a while it is back. (I have been driving the car infrequently due to bad weather.) And I note in every case the spurious down shift happens *immediately* when I pull the +paddle so it is clear how long the paddle is held makes no difference.
So bottom line there is a real problem with the +paddle signaling a downshift rather than an up shift.
This means for every potential up shift using the +paddle I have to concern myself with ensuring that if there is a downshift at the time of the intended up shift the engine RPMs are not too high and that the car is not in a turn in case the down shift occurs it doesn't subject the engine to an over rev event and any engine braking action from the lower gear being selected doesn't upset the car.
A few times after I was lulled into thinking this behavior was not going to appear the transmission downshifted from 2nd to 1st rather than up shifting from 2nd to 3rd. Quite an experience to be thrown against the shoulder strap/seat belt when this occurs and catch a glance a the tach as RPMs zoom up to over 4K.
As a result of this spurious down shift from the +paddle this pretty much renders the +paddle useless to me which means the paddles are useless to me.
I reported my latest experiences to Dodge Customer Care rep that I had been in communication with regarding this issue. Crickets.
You would think that Dodge would want to get this issue fixed before it causes someone to have an accident and sue them...
I have to think that it's a hardware-related issue and not just a simple computer bug that can be easily fixed. Will be interesting to see if they ever issue a recall for this.
Personally, I don't use the paddle shifters, so I don't know if the problem affects my 2018 GT or not.
An update on my paddle shift problem. after my last post on this thread for about 4 days the + paddle quit working no matter what I tried. But then I went to pick up a friend and I was going to show her that the paddle wasn't working during our drive. While waiting for her to get in the car, I thought maybe there were dirty electrical contact points under the paddle so I folded a piece of paper to make it twice as thick and slid it in and out of the gap between the paddle and steering wheel. I haven't had a lick of problems with the paddle since doing this. I don't know if there really are contact points there or if I just got lucky but the paddle is working fine since I did that a couple of weeks ago.
You'd think, but any number of times automakers have stonewalled on something and it takes deaths to then force an automaker to take action.
The paddles, particular the + paddle is a feature I was really counting on using. The shift lever is not very well positioned for constant manual use. And it requires one take his right hand off the wheel. The Hellcat is a car that one wants to have both hands on the wheel at all times. The paddles support that. If they worked right.
1 - 20 of 42 Posts
About this Discussion
16 Participants
Jimmy N.
Dodge Challenger Forum
Full Forum Listing
