1 - 4 of 4 Posts
Hey all, I've seen discussions, ads and pictures for "rear control arm" suspension modifications. From what I read, it is primarily to stop "wheel hop" but beyond that I'm really not sure. Unless, you buy an adjustable piece, I'm having trouble understanding the engineering benefit of swapping a stock piece for an after market with the same dimensions?
I have a 15 SPS with a front and rear tower brace and an Eibach front sway bar. I'm a "spirited driver" and do no track time or race. I like a tight feel (I'm a recovering BMW enthusiast) for corners and (as much as possible) want a solid, quiet body with no creaks, pops or other noises. I'm happy with the engine power and always on the look out for any (meaningful) suspension mods.
Anything to be gained with a rear control arm?
2019 Dodge Challenger Scat Pack Shaker
I put the BMR on-car adjustable ones on mine for alignment purposes on my lowered Scat. They do creak so I would stay stock if that's important. I did all 3 arms at once, plus cradle lockout bushings for better launches at strip.
1020676
shak3r-
Now THAT is a cool set up! You have done some great work and thanks for the pointers.
2020 Challenger R/T Scat Pak
There's an aftermarket rear control arm that allows you to adjust the rear camber.
1 - 4 of 4 Posts
