1 - 20 of 58 Posts
Okay I'd like to hear from the more experienced motorheads with either a "yeh or neh" on this build that I'm having done. I live in Minnesota and will be shipping the car to Virginia to have the work performed by Arrington. The build will take about 3-4 weeks and the goal is to turn 9 second 1/4's. Here is the build so please feel free to pick away at it. I would appreciate opinions based upon work that your have had done on your car.
1.00 AMI-426-SB 426 Short Block. BALANCED
1.00 HMI-PRGBM Pro-Gram Billet mains 6.1,5.7
1.00 coated bearings
1.00 Custom Blower cam and pushrods
1.00 Head spring package and valve job, springs, locators, valve seals
1.00 Mahle custom pistons 2816 / 927 wristpin
1.00 ATI-918437 Damper 6.1 7.074 OD 17% OVRDRV
1.00 ARP-244-4300 6.1 HEMI ARP Head Stud Kit
2.00 COM-HMIHG-61 6.1 HEMI Cometic Head Gasket .40
2.00 COM-HMIIG HEMI INTAKE GASKET (SOLD PER EACH)
1.00 Triple fuel hat system with upgraded lines, boost reference regulator, 3 Walbro GSS 342 255 LPH pumps....complete fuel system
1.00 SHR-NAG1-HTCr NAG1 HTC Transmission
1.00 TDS-CHSH5 SRT8 CM Drive Shaft
1.00 DSS-SRT8L5 Level 5 1400 HP Axle Set 09
1.00 BTC-10010 catchcan
1.00 Timing chain
1.00 MEL-OP-6157 5.7 - 6.1 Melling HP Oil Pump MEL#10342
Please also view the modifications that I've already had completed.​
I just tuned a similar setup with a SMS blower. Car made 650rwhp on 12psi spinning the blower as hard as it could be spun. Car would probably show close to 700rwhp on another dyno.
If you net that, you should be close to 9's, I'd say low 10's no problem. Shot of nitrous and 9's would be easy.
Good luck with your build, sounds like a nice setup they are doing for you. Atleast your car will be in some warm weather! Minnesota is getting pounded with snow as bad as we are here in Illinois!
Got to 3 pumps at 800rwhp. If using 2 pumps I wouldn't worry too much about a return line unless you are making less than 600rwhp. Once you go to three pumps, I wouldn't hesitate to go to a return style.
i would say keep the 3 pump at that level your gonna be pushing the limit to get to 9's
the only thing i see that you did'nt list would be bigger injectors.
and of course the required saftey equipment.
if you do need to juise it for 9 then the 3 pumps will come in handy once you cross that 800rwhp mark which you will need to do to run 9
how does that blower handle the heat at the higher boost level?
you may need some kind of ice box also, but i don't know anything about that blower
Can a 2.3l blower even make 15psi on a 426? Seems like it is not large enough to make that much pressure on a motor flowing that much air.
That's why I asked what the CR was going to be. And it' not just the size of the SMS unit, yes it can be spun up, but there are other limitations with the SMS unit.
but if he does juice it to get to the 9's it should make over 800 i would think
1 - 20 of 58 Posts
