ATI SUPER DAMPER 18% OVERDIRVE 2011-2017 5.7L/392/6.4L CHALLENGER/CHARGER/300
The patented ATI Super Damper is the only crankshaft damper designed exclusively for high performance Chrysler, Dodge and Mopar Engines - including the new HEMI!
Whether you race or just drive on the street, ATI's harmonic balancers are the perfect choice.
Eliminates torsional crankshaft vibrations
Exceeds SFI 18.1 specs
Black zinc chromate finished
OEM equipment on 392 Mopar Crate Engines
Tunable, rebuildable, and extremely efficient at ALL RPM
Laser engraved 360° timing marks
Inner and outer shells are available in aluminum or steel, and contain a steel inertia weight. This inertia weight has six (2-ring design) or eight (3-ring design) computer machined grooves to retain the proper durometer O-rings (dyno tested for each application).
To Order: ATI Super Damper 18% Overdirve 2011-2017 5.7L/392/6.4L Challenger/Charger/300
Thanks
Chris
good afternoon and thank you very much for the support, it is a challenger 2011 srt8 6.4, currently has intake, throttle body 90mm, longe tube headers, coil perdormance and I am about to install full exhaust 3 ", camshaft stage 3 of compcams, aem water methanol kit and manifold edelbrock. I thought that ati super damper can help me
