1 - 17 of 17 Posts
Just wondering if this is normal, but my auto door locks seem to have a mind of their own when it comes to locking.
The manual says they lock at 20mph or something like that, but min don't seem to care about speed. If I accelerate slowly they may not lock until 45mph. If I take off pretty hard they lock usually on the first try, but if I'm driving "normally" and taking off at a slow pace, it may take a couple stops or a pretty good speed (mentioned 45mph) before they auto lock.
Anyone else have something similar going on with theirs?
BTW mine is a 2011 Rallye.
Noticed the same thing, although I've never managed to get it up to 45, usually only around 30 or so idling through my neighborhood. Thought it was peculiar but also amusing, since as soon as I actually accelerate, or it shifts gears they'll usually lock.
[2010 R/T]
~S
All these dumb "options", if I want my doors locked I flip the switch, maybe if it was a mini van then it would be a safety issue but a performance car it's not needed.
Reactions: BlkSEbase
Mine do the same thing. Ill be taking it to the dealer next week and will aask about it and let u know.
Mine does the same.
My 2009 car is the same way. I always drive with a very light foot while my car is warming up. The doors don't lock, even when I get up to 65 mph on the highway (on my way to work). Until I activate the cruise control; then they lock right away. Or if at any time I accelerate a little more strongly, the doors will lock.
I don't like the nanny features either, but it doesn't really bother me since the doors unlock by themselves as soon as I pull on the interior door handle to get out.
Mine work just fine, always seem to lock at about 10 MPH.
You can set/change this in Personal Settings. Mine are set to lock at 15mph and they do. Locked doors are an extra level of protection in a crash.
I don't believe that is correct. Whether locked or not the latch will hold the door unless the sheet metal tears away.
I forget the name for it but the latch striker and lock are built to a certain government tolerance just like the brake pedal is built from a certain mandated grade of steel.
If in a wreck and the doors are locked they have to break a window which can pepper an occupant with broken glass.
In my opinion auto locks are good at stopping a car jacking. Yes they can just break the window but most of the time they run up to the car when your at a stop and open the door. It's not a safety thing for the people inside. The locked door opens when you pull the handle on most vehicles.
We all realize it's a setting but they do not lock when they r supposed to. I can make it almost all the way home from work and they wont lock at speeds of 50
1 - 17 of 17 Posts
