1 - 3 of 3 Posts
After doing a lot of searching on here, I think I've got most of the info that I need. I want to change out my pumpkin to one from and AWD charger, magnum or 300. The AWD pumpkin should be 198mm and 3.07 ratio, right? What I don't know is, can I get a differential from a V8 or V6? Are the the same?
Thanks
Yes, all AWD magnum/charger/300 use the 198mm differential with the 3.07 ratio regardless of the engine.
1 - 3 of 3 Posts
