Hello all. I know there are some very knowledgeable people on this site and when I have a tough question, my search usually leads me back here. This time, no luck, so I figured I would make a thread instead.
I am looking for any info on the AWD system. Specifically, I'd like to know how power is linked to the front wheels. Is there a center diff like how evos do it? Does the transmission have 2 axles sticking out the side of it, like how some audis do? Any pictures would be awesome too! Is there a front diff and if so, how does it fit with the engine in the way. Thanks in advance.
There's not much info on it to be honest. It uses the same system the AWD Charger uses. It has an active transfer case and front-axle disconnect. It does add a differential and front axle to power the front wheels. A Guy
Reactions: SRTFighter
I hope someone will post a pic from under the car so I can see.
I'd be interested in that myself. I thought a Google would bring up some technical explanation.
Not sure how accurate this pic is because it shows a V8 instead of a V6 but it does show the diff mounts to the oil pan and also possibly passes the driver side axle through the pan.
Here are some photos I took of mine when I had it on the lift. you can't see the front diff. because of the splash shield it is on the passenger side bolted to the oil pan and the drive shaft for the driver's side wheel goes through a tube through the oil pan to the front wheel.
