1 - 3 of 3 Posts
Hey I am hoping someone here can help me find a solution to removing the ball joints off of the control arms. I’m am replacing both upper and lower. I got all the bolts off but the ball joints won’t pop loose. I’ve tried using a pickle fork, ball joint remover, and tried beating it with a hammer. Still nothing. I don’t want to heat it up with a torch because I’m not replacing the lower ball joint and I’m worried about melting the ball joint boot. Anything will help thanks!
Mine were jammed in as well...
I used a snapon puller kit with a 600ft/lb impact and that thing gave lol.
See if you can borrow a puller from auto zone? Do you have a strong impact?
1 - 3 of 3 Posts
