Hi all...
Just a curious question... anyone ever remove 1 or both of the centering springs on the shifter yet... the shifter as is, is great... everyone so often I get caught with 5th to 4th ... I know it's me being lost in the moment, not thinking about it... seen a youtube video on it, just wanted to hear experiences...
:rocker:
I just removed both springs in mine. Well worth the 2 hours it took to R&R the unit (including the mod to the shifter) Pretty simple process. I didn't remove the lower boot, just worked around it. The shifter now has a crisp but manageable feel to it. The throws didn't change but the spring tension that created a wrestling match between me and the shifter is now perfect. To me, it feels like a high quality stock setup would feel.
I also put the Burl wood Mr. Norms classic shift handle in with it which adds a nice old school look to the set up. One note, when you use a Mr. Norms shifter with a Barton you will need to grind off about 1/4" of the front portion of the handle where it couples with the Barton. There is a bit of interference there, but not bad. Just takes 5-10 minutes of grinding and fitting. Doesn't compromise the shift handle strength.
Overall....was it worth it?? Na.... ~$700 is WAY too much to spend on a shifter setup. But what the heck. I'm 60 and plan to be buried in the car....I like to fiddle and it was fun.
Ide like to know more why you are removing the centering springs? This is a huge advantage of a short shifter. I wrestled with mine for a while but they loosen up a little over some mileage
I don't race my car. But it's a 2010 Challenger that had a very sloppy shifter. The Barton was the obvious choice to get in to a better shifting platform. Barton is probably the best if not one of the best out there.
Having said that, everyone has a "feel" they like...I just wanted less resistance to the 1-2 and 5-6 gates. It's much more comfortable for me to use now and I still get the advantage of a short crisp shift. This also basically eliminated the heavy "thud" it made as it shifted.
Like I said, I like to fiddle around with cars, so this project was not intended to make my 1/4 mile times better or reduce a 2-3 missed shift issue. I used to do all that stuff, but now I just like to enjoy the car for the nostalgia and fun it offers.
I understand why most Barton owners would be wondering about why anyone would do this. I just wrote this up to help anyone who might be in my boat.
When I was researching the Barton, I would have appreciated knowing there was someone who was doing it for these reasons.
Again....was it worth it.....na....but it was fun and I have a unique shifter that enhances the experience of re-living "the good ole days"..
2015 Dodge Challenger SRT
I considered doing the same thing but ended up leaving it the way Barton shipped it out of sheer laziness. Unfortunately, I have to use my Challenger as a daily driver and the Barton sometimes feels a little too engineered for stop-and-go traffic.
As time has gone by (installed in July 2018) the springs have loosened up some. However, I'm still thinking about a slight modification. Perhaps removing one spring.
