I turned my car on the other morning ('17 Scat Pack) and there is barely any sound, there is no bass and only seems like sound is coming from the front speakers. Has been working fine otherwise and haven't done anything crazy. Is there any easy fix or common problem with this? I hate to take it to the dealership and get charged an insane amount. Thanks for any help!
2012 Dodge Challenger R/T Classic
Man, guess the first thing I’d try is to pull out/check/replace the radio fuse/amp fuse. My car is older than yours, so can’t tell you which ones they are, but I’m sure they’re in the trunk.
good luck,
J
Which audio package does the car have (assuming it’s still stock)? If it’s for either of the upgraded packages, there is an amp behind the knee bolster that may have crapped out. Although if it went out, I’d expect all the speakers to stop working and not just a few.
Either way, that’s where I’d start the diagnosis - the audio source, whether that is the amp or the head-unit (in a non-amped base audio package). If there is no sound coming from the audio source, the problem is upstream from it.
If the head-unit is the audio source and no sound coming from it, it would seem to be the problem component.
The way I read this is the car has an upgraded sound system. My thought is the amp is dead, or mostly dead. I don't see anyway else that something would cause this.
