1 - 3 of 3 Posts
BBK PERFORMANCE 78MM THROTTLE BODY 2011-2018 3.6L CHALLENGER/CHARGER/300
Do you want to add more horsepower along with better throttle response to your Pentastar 3.6L equipped Dodge or Jeep model - well now you can with this new BBK Performance Power Plus series Pentastar 78mm throttle body.
It was only a matter of time before the BBK team of engineers came up with this new throttle body design for the popular 3.6L Pentastar applications/ This throttle body has a larger bore opening over the stock 73mm unit to increase airflow and deliver 9-14 rear wheel horsepower over stock along with improved throttle response.
This makes this unit a simple plug and play direct fit with no modifications required, best of all no tune is required - it will bolt right up and go right out of the box!
This Throttle Body is 50 State Legal CARB EO# D-245-21
35% More Airflow
Increased Horsepower,Torque and improved Throttle Response
9-14 Horsepower Gain is Typical
Direct Bolt-On
OEM Electronics
Top Quality Construction
BBK 3.6L Pentastar throttle bodies are CNC machined from high quality 356 aluminum castings to ensure perfect quality. Features new electronic controlled injection molded plastic gear assemblies for modern drive by wire applications.
Easy Installation
This throttle body bolts on easily with basic hand tools. BBK throttle bodies work with OEM air intakes and aftermarket cold air intakes to ensure perfect fit and excellent performance.
To Order: BBK Performance 78MM throttle Body 2011-2018 3.6L Challenger/Charger/300
Chris
1 - 3 of 3 Posts
