1 - 20 of 39 Posts
We have the 85mm & 90mm throttle bodies and cold air intake kit for your HEMI in stock at our Florida facility, and ready to ship!
85mm HEMI Throttle Body
Info / Order: BBK 85mm Throttle Body 05-10 Challenger, Charger, 300, Magnum 5.7L, 6.1L
90mm HEMI Throttle Body
Info / Order: BBK 90mm Throttle Body 05-10 Challenger, Charger, 300, Magnum 5.7L, 6.1L
HEMI Cold Air Intake Kit
Info / Order: BBK Cold Air Intake System 05-10 Challenger, Charger, 300, Magnum 5.7, 6.1L
Give us a call toll free if you have any questions or would like to order over the phone! 888-SPD-LOGX
Discussion Starter #2
We got more in today, so everything is in stock!!
Throttle Bodies...
In stock!
BBK Cold Air Intake Also In Stock!
A few of you asked for some up close pics of the Throttle Bodies so here a few more pics of these we took today.
Great mod for your 5.7 or 6.1! Lowest priced cast TB on the market! Made in the USA. In stock and ready to ship!
BBK polished Cold Air Intakes and Throttle Bodies are in stock!
Alot of people ask what kind of gains can be had from a TB like this.
Here is a writeup from a forum member (hemifever) about his experience/testing of an 85mm BBK Throttle Body on his 5.7 Challenger
I did a pre/post dyno of a BBK 85mm TB. The car is a 2010 R/T 6 spd Challenger. Mods for the pre-dyno pull are DSP, 180 stat, Flowmaster 44 cat back, and Mopar CAI. I made 3 pulls in this config to ensure the tune was good. 1st pull was to blow out the carbon. 2nd pull backed up the first. I then pulled the fuse to simulate a pcm reset so tuning the tb would be more of a fresh pcm reset comparison. The first three pulls had 11.9 to 12.0 a/f with a max KR of .5 through the pull. Nice solid tune. Then I put the tb on. KR was 2.5 and a/f went as high as 12.8 through parts of the curve. I liked my timing curve where it was so I richened it back up to a 12.0 to 12.2 curve and ended up with a max of .5 KR which matched the initial pulls.
Basically there was about 11 hp and 15 tq increases through most of the curve. I was pretty impressed with it. The dyno I went to was 2 hours away mostly interstate. I gained 1 mpg on the drive home. TB, 1/2 tank less gas (less weight), fresh pcm reset, and pouring down rain. So those gains could be any and/or all of the above.
The initial pull after the tb install showed .1 PEAK hp less and 3 PEAK tq increase. 3 and 4 hp gains through the curve and about 7 tq gain. It made a nice difference tuning out the KR from the leaner a/f ratio. Bringing the 12.8 a/f back to a 12.2 picked up a good power increase without the KR
Very easy bolt on mod, proven to pick up hp. We have 85 and 90mm in stock and ready to ship
Great mods! In stock @ Speedlogix!
Here is another pic of a BBK TB installed on a customer car!
These throttle bodies are a great mod for your Hemi! Fit all 08-11 5.7, 6.1 and 6.4L cars!!
Have you put an 85mm on ur GWE car yet?
has y'alls 392 gotten one of these tb's yet for a review?
We haven't had the chance to get to the dyno yet to do a before after on the 392 with the tb.
we have these available for delivery!! get better throttle response with an upgraded throttle body!!
BBK Throttle Bodies are always available from your friends at Speedlogix!!!
BBK throttle bodies are in stock and ready to roll out!!!
BBK throttle bodies are in stock and ready to roll!! :)
1 - 20 of 39 Posts
