I have an RT and recently I installed BBK headers with the gasket it brings. But it is heard escaping compression. I was recommended to install the original Mopar gasket. I need suggestions
Pull them and install oem...only way to go in my opinion.
do the oem gaskets work with long tubes as well?
Yes they do. Use 6.1 gaskets on anything after 09’. 5.7, 6.1, 6.4. You may have to alter 5.7 gaskets for longtubes on pre 09 5.7s tho.
BBK headers don't have the D port, at least they didn't in the past. That mismatch causes issues with performance and sealing with their gaskets, you may want to check that. But either way as mentioned the OEM exhuast gaskets are the way to go.
