But I can't seem to find it (most SRT guys add much more than I intend to). Q: I intend to add a Magnusson Super Charger to Stock SRT. Will have performance tune. I will NOT add anything else. I assume the HP increase will be different than a 5.7 with similar arrangement. How much HP/Q gain can I expect with 8 psi boost?
I would guess around 120 whp with a custom dyno tune. That's about what I gained with the exact setup your thinking of going with. Other than catback which really don't count.
That is impressive with only 6.0 psi. I'm guessing approx. 135 additional ponies (I believe the 5.7's pick up about 110-120 with 6.0 psi---from what I've seen on these threads). I believe Magnusson sells warranty for the motor (extra charge) if you only run 6.0 psi. May rethink 8.0 psi. 558 is plenty.
I agree; having 500-520 rwtq available from 3.5k - 5.5k rpm is well more than enough for this car on the regular roads.
