1 - 3 of 3 Posts
Looking for recommendations on the best bang for your buck for full length headers. Any suggestions and pictures of your installs would be appreciated. Thanks.
Joe
Best bang for the buck - so cheapest you can get by with? Stay away from $2k quality sets from ARH, Kooks, TTi and Belanger then. Regardless of whatever long tubes you eventually get, real performance gains won't be had until you get a custom tune for it.
Install is a PITA on jackstands and your back but doable. Plan on it taking a full workday. Loosening the engine mounts definitely helps with the additional 3-5" lift it gives you. Protect the O2 sensors and put back in same relative location (e.g. driver rear). If you break an O2 extension Caspers Electronics sells them under $25. Driver's side ain't too bad because the coolant reservoir and air filter areas give you room to maneuver. The passenger side however is a wall and you have the dipstick to contend with too.
Another option builders/mechanics seem to use is pulling the actual heads and installing the headers on the work bench. Oh, the SRT header bolts are cheap and come with a thread locker already applied. And consensus is to only use the OEM Mopar gasket.
1 - 3 of 3 Posts
