1 - 10 of 10 Posts
im looking for around a 2-2.5" drop for my R/T looking for a good handling setup
im also getting ready to buy my wheels as well(22" racelines or vipers)
will i also need new shocks as well? what brand is the best
car is just my weekend warrior/show car
if you lower it and have 22s, make sure they will clear the wheel wells. all the 22s i have seen will hit the body when lowered.
I'm not sure about the 22's being an Issue or not, but I have the Eibach Sportline plus kit on my SE, the drop was a full 2 inches. The springs plus sway bars made a major difference in the handling as well.
1+, Eibach seems the most popular option..
If your looking to get really low then go with fully adjustable coilovers and be done this way you can adjust for your desired clearance also this will set you right for changes down the road... I caution you they are pricey but that's my suggestion...
well i just bought my 22" lorenzo wheels 22x8.5 and 22x10 so i cant wait to get them on tomorrow
I installed the Hotchkis 2" drop kit on my '09 R/T (springs, swaybars) and loved it until I noticed the alignment had chewed up the inside of my front tires. Front spoiler hit everything, curbs, dogs, small pebbles, so you'll have to get used to that. Also, If you go more than 1/5" drop you'll need to fix the alignment issues. Many kits on the market to do this, just pricey. Without it you will wear out your tires pronto. Hotchkis makes a great lowering setup and probably has the best handling out of any of the kits available, but it is a little rough over the bumps. You'll need to get new shocks, as the stock ones don't work very well with the drop. If you can swing the alignment kits to go with it I'd go with Hotchkis instead of the coilovers.
On my new R/T I went with the Eibach 1.5" pro kit (springs and shocks - bought from TireRack online) so I wouldn't have to mess with the alignment issues. Very happy with it. Ride is great, not harsh at all, and my 20's clear without any problems and just clears most parking blocks.
At any rate, that's what I've learned.
The word "best" is subjective, but I've been more than pleased with the Mopar Stage One lowering springs.
They did everything that I wanted, but maintained the ride quality and gave me the "drop" that I was looking for:
Also have to worry about the Nivomats if the car has them. . At 2" of drop I'd go Eibach Sportlines personally on a non-daily driven car. If daily driven I'd go with the Stage 1's like 19johned53 recommended.
1 - 10 of 10 Posts
