41 - 56 of 56 Posts
In 1972, AMSOIL 10W-40 Synthetic Motor Oil became the world's first synthetic motor oil to meet American Petroleum Institute requirements
Surprised if anyone hasn't heard of them, but hey :)
Yea I call BS on someone saying they've never heard of Amsoil.
Lol, calling BS?
What's the big deal? I've never heard of it til I came to this forum. I've only used synthetic oil in one car ever and it's my wife's current car, and i use either Valvoline, Quaker State or Pennzoil....whatever is cheaper at the time. I'd also use Mobile 1 or Castrol but don't use those very often.
It's all I've ever used in conventional as well so cult following or not,.... Amsoil is not a big deal to some people. I don't buy oil that cost that much and never had a problem with any of my vehicles engines.
And sorry to say, never heard of Royal Purple either til I came here.
Amsoil has a cult following. Like Royal Purple.
I believe it does, but I use it because I read up on oils, and it topped the list for me. I will reccommend it, but won't tell you it will make your breath fresher too...
Lol, calling BS?
I can believe you. Unless you belonged to car forums, you may never have run into it IRL. Just like that BNB oil, I'd never heard of that before this forum. They have a cult too, lol. I imagine Redline and Lucas could also be something most are unaware of
Honestly, and goof oil will probably serve you well as long as it's the correct viscosity. I only change once a year, so I don't mind splurging. I sure have spent enough babying this car
Ive seen the convention oils set a code. Says improper oil. Synthetic is the proper oil for the hemi. The code wont set the light but it is stored.
Ive seen the convention oils set a code. Says improper oil. Synthetic is the proper oil for the hemi. The code wont set the light but it is stored. View attachment 994045
For the 6.4 and 6.2 engines?
5.7 don't call for synthetic. It's right in the manual.
That pic was taken from a 5.7. 2012 r/t.
Ive seen the code in 6.4 car also. Wont turn the light on for the code, but does store it in the pcm.
I understand what the "book" says but the engine can tell the difference between the conventional and synthetic.
Do you use the once a year oil?
Ive seen it advertised and idea sounds good, but with all the plastic plates under cars these days a leak would become un-noticed. Checking the oil becomes the only thing that you can observe. The ones that dont check oil regularly would be in trouble.
I use Amsoil Signature, their best. It's not specifically advertised as once a year. It does say extended interval, so could go 10,000-15,000. I average about 4,000 miles a year. I check it fairly often. I have never had the belly pan off as I use an oil extractor to remove the old oil. I'm not very concerned with a leak I won't see, but my car is still mostly a weekend car even though it's my only car. I could see it being an issue with daily drivers, high mileage, engines that have been modded etc.
Ok.... I see all this mention that a thicker oil will cause MDS damage, but the 392s have MDS and call for the 0w-40. so What is the difference? Seems to me the MDS solenoids and lifters are the same.
Perhaps different tolerances on the 6.4, and not just MDS dictate the viscosity
41 - 56 of 56 Posts
