1 - 1 of 1 Posts
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
Select a specific model below to learn more about our brake kit line up and review vehicle applications.
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
Key Features
  1. 12 Piston Aluminum calipers
  2. D.O.T. Compliant Stainless steel brake lines
  3. Machined aluminum hats
  4. Carbon steel brackets
  5. Disc size varies upon brake size.
  6. High quality Ksport SC5 street brake pads (RC1 race pads available for additional cost)
14 Inch Procomp Front Big Brake Kit (18" wheels required)
8 piston front and 6 piston rear.
15 Inch Procomp Front Big Brake Kit (19" wheels required)
12 piston front and 8 piston rear
16 Inch Procomp Front Big Brake Kit (20" wheels required)
PM me for pricing!
the kits are sold front and rear sets.
1 - 1 of 1 Posts
