Billet Catch Can Kit for your 2008-14 Dodge Challenger 3.5, 3.6, 5.7, 6.1 or 392. Developed to eliminate oil from entering your intake by engine blow-by, which channels oil and trash into your direct air stream from the valve train. This is a common problem on both brand new performance and especially older engines, which just suffer more from blow by due to wear and tear.
The most common problem is making your car emit light blueish white smoke upon start up or even during normal driving. The throttle body handles your main air stream and has a breather tube running from the crankcase to the throttle body. The vacuum from the incoming airstream and positive pressure in the crankcase combine to get oil in the air tract.
Every car and vehicle is set up this way to help eliminate the pressure build-up in the bottom end of your engine enabling the piston to move up and down with less resistance.
These catch cans feature a containment system and separator that force all the debris to get captured and contained in the filter while still allowing airflow thus maintaining full function of the breather system.
Another key problem caused by oil in the intake is that it reduces the octane of your fuel and causes detonation especially in turbo, supercharger and nitrous applications.
The UPR Oil Catch Can features a three chamber design CNC machined from 6061 Billet Aluminum unlike some of our competitors models that are single chamber tanks that don't properly trap the oil or debris.
Installs in 20-30 minutes or less.
Made in the USA!
These Catch Cans are available in Satin, Polished, or Black Finish, and come with all hardware and hoses needed to install. Hose barbs are available in Black or Nickel Finishes. The can has a mount designed specifically to work with the Challenger!
The can can be emptied by unscrewing the bottom, or by adding an optional drain valve to the bottom of the can.
Unlike some of our competitors there are no long lead times for our Billet products, we keep them readily on hand here in our South Florida warehouse/showroom for immediate shipping.
For more information or to order:
08-14 5.7, 6.1L
UPR Billet Oil Catch Can 05-14 Challenger, Charger, 300, Magnum 5.7L, 6.1L
11-14 392
UPR Billet Oil Catch Can 11-14 Challenger, Charger, 300 392/6.4L
08-10 3.5L Rear Mount
UPR Billet Oil Catch Can Rear Mount 05-10 Challenger, Charger, 300 Magnum 2.7L/3.5L
11-14 3.6L Fender Mount (will also fit 5.7, 6.1 or 392)
UPR Billet Oil Catch Can w/ Fender Bracket 05-14 Challenger, Charger, 300 3.6L, 5.7L, 6.1L, 6.4L/392
Cans come standard with rubber hoses, if you would like to upgrade to braided lines click below:
http://www.speedlogixstore.com/product-p/sx-blp-mopar.htm
