Billet Oil Catch Can installation issues on 2019 SP w/Shaker hood
1426 9
Went to install my oil catch can from Billet w/z-bracket and ran into part of the wiring harness smack in the middle. The can will not fit properly and I do not think I could unscrew the can to empty. Anyone else have this issue?
997382
1 - 10 of 10 Posts
2016 R/T Scat Pack
Welcome from NC. Pull that plastic clip out holding the harness, it's a threaded hole for the mounting bolt.
Auto part Engine Vehicle Car Fuel line
Reactions: Grinch_392
2016 Scat Pack Shaker
I have a BT, had similar issues. Keep working the harness, maybe a little heat will make it easier to reposition. Space to remove and reinstall is minimal but it works. Hint, when installing the bowel do not over tighten. Contact with the O-ring + just a little more has proven adequate on mine.
2015 Dodge Challenger SRT
Edit .... after a little caffeine I decided to keep my smart-$%$ comment to myself. Sorry.
Discussion Starter · #6 ·
I’ll give it another shot. Also, seems as if I can wedge this in, that wire will be right against the catch can, which from what I read, gets really hot. Wondering if I should protect that some.
Do you have a pic of your catch can so I can see how it looks for further reference.
I had a speedlogix one for my 19 Scat shaker and ran into the same issue. No matter what I did it was rubbing on wires and sat so low I couldn't get the bottom off to empty it. I switched to a UPR catch can and couldn't be happier with the fit and quality. Perfect fit for a shaker car.
Pic is from UPR website
Sent from my Pixel 4 XL using Tapatalk
I don't have a Shaker but I do have a UPR catch can. I just ordered the straight bar bracket which bolts to the unused stud on the water pump. The catch can sits above the alternator. When I empty it, I place a rag over the alternator just in case I drop the can. I don't know if there is enough room with this set-up to clear the front of the Shaker but it looks like it would fit. You don't have to touch the wiring harness with this set-up.
Discussion Starter · #9 ·
Thanks for the input and pics. I was looking at that UPR catch can today; I think I will give this one a shot or try a fender mount. Unfortunate, the Billet did not fit properly; guess I should have done more research.
Also, I find it odd that I have a wire coming from the front of the fuse box and directly over alternator and from pictures, several other Challengers do not. I would think that would be pretty consistent, especially for the same model year.
997469
I have a Shaker and used a lower hole to mount the z bracket which avoided most of the contact with the harness.
Reactions: Southpaw392
1 - 10 of 10 Posts
