1 - 20 of 21 Posts
for a short time only
$6995.00 2011 to 2017 Challenger 5.7L basic kit 6 psi, parts & professionally installed here!!!!
$7995.00 2011 to 2017 Challenger, Charger 5.7L upgraded to 8 psi, parts & professionally installed here!!!!!
$7995.00 2011 to 2017 Challenger, Charger 6.4L 6psi system with fuel system upgrade, parts & professionally installed here!!!!
$299.00 additional if pcm is not unlocked
$499.00 additional for oem shaker vehicles
https://www.stevewhiteparts.com/
special promo code """ TURKEY """"
Note, specials cannot be stacked or added together!!!!!
Discussion Starter #2
981381
promo code """" TURKEY """"""
981996
why wait till Friday......:cool:;)
promo code TURKEY...... ;)
Luke, I am looking for a set of front/rear splash guards for a new style 2019 Ram, without fender flares. All I see are a front set only. Are the rears available?
be a little more specific.....what size??
Im guessing new body style DT, in 2019 you can have a DS body or DT body
Discussion Starter #13
no, short block minus cam only,
Luke
Speaking of cam, do you stock redeye cam? I believe the specs for standard HC and RedEye cam is different. If so, whats the part #? I might just order the cam along with the block if you can ship it together.
also, after I order the block, is it possible to get a list of all the timing parts to ensure I order accurate parts for the install?
Discussion Starter #15
Discussion Starter #16
be glad to help
Discussion Starter #17
promo code TURKEY will work until early next week, dont miss out
Luke ;)
Luke,
I am looking for passenger half shaft for a 2015 RT Plus 5.7, perhaps both sides if there is an upgrade available. Will the Hellcat part fit or is it the same P/N as mine?
Discussion Starter #19
depends on which axle you have, some R/T's came with the smaller rear axle, pm vin number
Luke
1 - 20 of 21 Posts
