I didn't get any pictures during the install because it was cold and I busted my knuckles too many times to even pick up the phone, but I figured I'd outline some of the install for these.
First, the instructions they provide give a TON of extra, unnecessary steps. I didn't have to remove the fuel line, shocks, e brake cable etc. For the back 2 bushings I literally just took the bolts out, let the cradle drop enough, put the ring on top, and then the bottom washer type piece after shaving the excess rubber off the bushing and tightened it up with a little space for movement to do the fronts.
For the fronts I had the stupid limiter plates, I used a 1/8" drill bit, then 1/4", then 3/8, and a pry bar to pry them off, pretty straight forward. Then again trim excess rubber off bottom of bushing, and repeat the same steps. Bolts get torqued to 124ft lbs.
This all took me about an hour, hour and a half. You will find it much easier doing the fronts with the wheels off to get easy drilling access to the limiter plates if you have them. I had to use a few washers on the upper trailing arm bolt so it could clear the lockout plate on the driver's side, and 1 additional washer on the passenger side, this was not detailed in the instructions. The trailing arm bolts are torqued to 83ft lbs
Tools required-
18mm socket
ratchet
breaker bar
Torque wrench (for 83lb and 124lb)
Razor blade preferably with a long adjustable length blade
Drill with 1/4 and 3/8 bits, preferably a smaller bit for a pilot
Jack,2 Jack stands
18mm wrench (to hold nut on lower railing arm upper bolt)
Tools required-
18mm socket
ratchet
breaker bar
Jack,2 Jack stands
