On my 2012 SXT PLUS the two center bulbs on the right side will not illuminate on turn signal\brake\hazard mode. I do have sequential lights. I have replaced bulbs with no luck. The tail lights work fine. Any help?
The tail lights and break lights use different filaments in the light bulb. This is a weak guess, but did you check your after market wiring harness to see if any connection came loose?
