Anyone put a SLP Brake line lock Kit on their SE? SLP said its designed for the RT but I have the same 4 lines up/2 side out ESP module on my 2010 SE that the installation shows so will this work you think? I'd like to spare my rear brakes for burnouts.
Bump!!!!!!
I need this. Hopefully it will help. When I have my DRs on I can't stall higher than 25-2800. Then I start sliding.
It should work fine. The R/T and SE brakes are virtually the same. As far as I know the only difference is the front rotor (13.6" on R/T vs. 12.6" on SE) and caliper (2 piston on R/T vs. 1 piston on SE).
