Will the front brake calipers from a 2012 -14 jeep srt-8 fit on my 2009 srt-8 challenger
I've been wondering the same thing... They obviously "Can" fit, because the spy photos of the HellCat shows it with the 6 piston front calipers. But what is required to fit, if anything, I don't know!
Having two more pistons wouldn't it require more as far as the mastr cylinder and actual volume of fluid being moved.
Sent from AutoGuide.com App
If the six pistons were the same size (bore/stroke) as the four pistons, then yes. But typically the pistons
are smaller so they may actually equal out to the same displacement.
Bolt pattern for the 12-14 Grand Cherokee front Brembo is 140mm vs. 130mm for the old Brembo, 10mm or 3/8" of a difference. The piston dia. of the new GC Brembo is approx. 39mm. I assume the stroke to be same as the 2 pistons because of the design envelope parameters. Area of a circle is π x R². Total area of the 3 piston faces added together is 3582mm (approx.). If someone has a 2 piston on hand, they can do the math and post to compare.
