I am having arrington install a magnacharger on my 2010 r/t auto. I am keeping it at 6lbs of boost . I am also gettingh their cold air intake and currently have a mopar cat back exhaust on the car. I am wondering if the transmission will need to be upgraded or should I get some durability out of it? I figure once we are in the shop whats another $1000 if my tranny is only going to last 6 months with that kind of power. Thanks, steve
You can upgrade the valvebody (paramount performance) or put in the blue top shift solenoids.That will help the trans last longer with faster ,firmer shifts.
A mild upgrade of the tranny can't hurt but I wouldn't drop much on it at this stage unless you see yourself going up in boost. If the block is stock, it'll only stand another 1-2 psi for long.
Enjoy the new found powa'!
HemiSam
Your tranny will eventually give you problems. Like Sam said, I wouldn't put much into the stock unit, if any, and save the pennies for a new Pararmount or Shouthern Hot Rod unit next winter. It will depend a little on how hard you drive the car and what tires you have. The power is addictive!! Have fun!
I think it will depend on how hard you drive the car. If you just drive around town and get on it here and there I think it'll last a long time. You're going to be a tick under 500RWHP and while that's a significant increase over stock, unless you're the type that smashes the throttle to the floor from every red light I think the tranny will last you a while.
When you do start to feel it slip at shifts, then do an upgrade.
My .02 cents.
Welcome to the blown club.
