I’ve been on this road since October. I prefer NA engines and have collected the 392 intake, SRT headers, head pipes with cars…yeah, I live in an emissions inspection state. I have finally decided on a cam..akmost anyway. The Comp Cams Stage 2 NA cam looks good…so dies the XFI 223/232 cam…called the 274 cam, too. When I cam my R/T I’ll
port the heads, intake and get a larger bore throttle body. Then there is that almighty tune. have been looking at the HP Tuners setup…reading charts and tables, cause and effects.
These mods should comfortably get 420 at the wheel…most likely more.
The 274 cam with supporting mods that gets you 100 hp is way to big for the 5.7L unless you do not plan to daily drive the car. More problems with that cam and the 5.7L than you can imagine even if you get the tuning right.
In order to get max power from a cam on the 5.7L you will need long tubes. Shorties will just not cut it. I went that route with a custom Cam, 6.4L intake, heads and just made 385 hp to the wheels. Swapped out the shorties for long tubes and I ended up with 410 hp to the wheels.
I see you have the 13 RT with 6M. I would recommend replacing the lifters when doing the head work. Dodge did not change the lifters until around MY17 and on. So any MY before 2017 is going to be prone to the cam/lifter issues.
If you are doing the work yourself you save tons in labor, but if you are paying a reputable shop to do the head, cam install plan on some high fees and labor hours. The days where you could get a cam package for $3000 are long gone. It is now north of $5000 for the cam install with pulling the heads to install the PSI springs and pushrods for the cam. Does not include head work like porting.
I advise all that want to stay NA and are thinking about a cam install when a performance shop is going to do the work, to add up all the costs. Springs, pushrods, cam, limiter, lifters, headers plus the installation costs and see where they end up. You will be surprised what you can get today for a few dollars more. New 6.2 Hellcat Longblock for the 5.7L or 6.4L engine is just $7700 now.
Hellcat 6.2L HEMI Longblock 5.7L and 6.4L HEMI Engine Swap
www.modernmusclextreme.com
