1 - 3 of 3 Posts
On the way into work today I look over at the dash, right above the glove box. There appears to be 2 raised lines, roughly about 9-10 inches apart, running parallel to each other. It doesn't "look" right. Does anyone else have this?
yep we all have it it's your airbag for the passenger
Some are worse than others but yep, its the airbag spot. Some are actually so bad that it dips over a 1/4 inch. You can get it replaced if its bad enough. Unfortunately the new dash will start to do the same thing.
1 - 3 of 3 Posts
