1 - 3 of 3 Posts
I am gonna so c quartz uk
2 questions
1. Is there a min temperate I can/ should apply?
2. How long after do you apply reload after application. Seams there is mixed opinions. Also how often do you guys do reload after ?
CQuartz UK recommended working temperatures: 40F to 80F
https://www.carpro-us.com/protection/cquartz-uk-edition-30ml-kit/
Application may vary depending on temp and humidity
https://www.detailedimage.com/Ask-a-Pro/carpro-cquartz-uk-edition-application-process/
Reload may be applied 1 hour after application, not before that, if you think your vehicle is going to be exposed to rain within a 24 hour period. Some folks may not be able to keep their vehicle in a garage overnight. If you think it may get wet, apply reload. Otherwise, depending on storage condition, garage, under cover, outside, exposed to weather, etc. My car is outside in that it's not enclosed, but parked under building open at either end. I applied after 6 months. Basically if you like to wax, after coating, use Reload when you want to "freshen up" the coating.
Coating fully CURES 30 days after application. DO NOT use any harsh cleaners, APC's, Iron X, Trix, Tar X until then. As Tad pointed out, do not wash for 7 days. 7-30 day time frame, soap and water only.
This is Corey the owner of Carpro
https://carproforum.com/showthread.php?3-How-To-Apply-Cquartz-UK-2014
Reactions: IRdetail
Thanks for the info
1 - 3 of 3 Posts
