2015-2018 Dodge Challenger R/T and SRT8:
Tach: Green wire of shift light (engine speed) goes to PCM, Connector 2 (C2-Black Connector) pin #51. This is a dark blue wire with a dark green tracer OR yellow wire with a dark blue tracer.
***Only 2 connectors on PCM
You can also get this signal at any of the ignition coils.
For Dual Mode Shift Light:**The dual mode shift lights must be FACTORY pre programmed to work with the clutch switch and not the standard default Vss signal. Clutch switch signal at PCM, connector 1 (C1-Grey Connector)) pin #39 (dark green wire with orange stripe).
** If Automatic transmission, connect to brake switch signal
>Click for C1 connector view
Connect red wire of the shift light to a switched power source and the black wire to ground (frame).
The cylinder setting must be set to "1 cylinder" mode since we will be reading from a single coil.
