Caliper paint
3592 Views 10 Replies 2 Participants Last post by  19Scat
So I have not been able to find high temp caliper/engine spray can in Bronze just in gold which is just lighter nothing with flakes, but I have found it only in rim paint, so I was wondering if I spray the calipers in high temperature primer or a base color of high temperature gold, then the bronze rim paint then on top a clear coat of high temp as well will that hold on the road and on the caliper?
1 - 11 of 11 Posts
· Super Moderator
Do you have an example of what color you want? Bronze could be any tint
Burnt copper?
994941
This appears to be VHTs gold
994939
· Banned
Burnt copper?
I am looking bronze to match my Brass money wheels, the burnt copper is just too bright compared the brass monkey wheels, the lighter gold like VHT but made by duplicolor and since it’s lighter it maybe a good contrast, but that’s my last plan if I can find a bronze like this
That is closer to my brass monkey wheels
Product Auto part Automotive wheel system Cylinder Solvent
That’s why I was thinking of high temperature primer on the bottom and high temperature clear on top to protect the paint in the middle
· Super Moderator
This guy does just that
· Banned
Discussion Starter · #5 ·
Yes but all of them use High Temp caliper Or engine paint spray , the only bronze I found is not high temp but Rim paint,
so idk if the paint will hold up to the heat of the calipers on my Scat
so I was wondering if I do a high temperature primer on the bottom and high temperature clear on top being that the rim bronze paint that is not high temp
But it would be in the middle, will it with stand the high temperature like a traditional high temp caliper paint
· Super Moderator
Did you see the video? he does just what you are saying, high temp primer, high temp clear and regular base coat
· Super Moderator
I agree, I think beyond power coating, this is your best bet
· Super Moderator
Sounds like a career ;)
1 - 11 of 11 Posts
