Recently my car started overheating after a short period on the road.
My initial hope was that the coolant reservoir cap was failing and any water was just starting to boil out. Replaced it and made sure to run any bubbles out of the system (heater took a LONG time to get heat back). I let it run in the driveway for a while at temp and it held stable. Once I got it out on the road and started putting it under a little load it seemed like it was going to be fine. Temps were going up and down like normal. Then after about 5-10 minutes on the road, babying it the whole time, temps just start going up. They keep raising until the coolant starts to boil again and once that happens there's no coming back. Need to shut it down and let it cool and then it will repeat the exact same 5-10 driving window.
So I next turned to the 180* tstat. Ended up getting a stock stat for now and put it in, raised the fan temps, got all the air out of the system, and let it run for a bit to see if it was even stable at idle with the hood closed. It did fine running in the driveway and was still able to hold stable temps. However, when I took it out it exhibited the exact same behavior.
At this point I figured maybe I've topped it off with water too much so the boiling point is much too low and that's where the issue is coming from. So I filled the system with just coolant (Plus whatever coolant/water mix was in there still). If I had to guess I would say it was at an 80/20 mix so the boiling point should be pretty high. Well I bring it out again and things actually seem like they will be fine. Then... this car once again did the one thing I've come to depend on it for.. Started overheating again. Boiling seemed to start later but it boiled none the less.
And that's where I am now.
The temp sensor was relocated on my car so its got me wondering if that may be part of the issue. Its now attached to a 90* that's going to the top of the water pump. I don't remember what temp it got to exactly before I stopped it but I'm pretty sure the sensor showed the coolant at 220* and oil at 245*. This kinda made me wonder if the sensor was the issue and the fans weren't coming on.. But that may not be likely because I've had it start overheating on the highway at medium speeds (45-55).
I also know there was some question about one of the head gaskets maybe going on wrong but we decided that wasn't the case and it probably went on right. I only bring it up because I'm getting white smoke on start-up and a lot of moisture coming out the tailpipes. I'm blaming that one on the overflowing coolant drenching the filter in the finder right under the tank. There's also no signs of oil in the coolant however there is a bit more floating debris and some sediment at the bottom of the tank. The floaters seem new or like they've started collecting quick enough to notice a difference and I don't really know if there was any sediment in the bottom of the tank before (its maybe a tablespoon of what looks like extremely fine dust).
What would everyone take a look at next?
Motor is a forged 5.7 at 9.75:1 and a 2.8l KB. Everything seems to be running alright... Its just the cooling system not being able to keep up.
