1 - 4 of 4 Posts
I do not mind the default location for the catch can however, is there more room to unscrew the bottom when using the Z bracket?
Thanks
Site
Yes the z bracket gives you even more room to access the bottom of the can
Does the z-bracket bolt into a an available screw hole int he head or block and if so, does it come with the bolt? I cannot tell from any pictures I have seen.
Also, does the z bracket replace the original bracket in the order or is the original bracket included as well?
Thanks
1 - 4 of 4 Posts
