I ran into a bit of bad luck installing my new 87MM Throttle Body. I noticed that when I removed the throttle body screws, they seemed fairly loose.
When I went to tighten down the new throttle body, the threads were stripped on the two bottom bolts. I attempted to get the top bolts to torque to 105 in lbs and they were going to strip as well.
Just for clarification, my torque wrench is a CDI and is accurate on others bolts.
So... I ordered Ez-Lok press inserts for plastic. https://www.grainger.com/product/E-Z-LOK-Press-Insert-4ZU14
I ordered some 8-32 x 1.5 Hex screws as well.
The 8-32 press insert requires a 7/32 drill bit and you can essentially enlarge the existing holes with minimum effort. This also leaves plenty of meat in the plastic for the press inserts.
I also wanted to go with a 32 pitch bolt for better bite. I can't believe Dodge installed a M6-1 in plastic with no insert.
Hopefully this isn't a trend on the newer cars....
Hopefully this will work. I certainly believe the press inserts will hold 105 in lbs.
