1 - 19 of 19 Posts
New Mopar 1320 Drag Racing Performance Springs and Sway Bar Kit
Part # swm1320
Fits 2011 to 2019 Dodge Challenger
Same package found on the new Challenger 1320 Special Edition Vehicles!!!!
Includes front and rear springs, front and rear sway bars with bushings!!!!
2 front springs, 2 rear springs, front sway, rear sway bar and 4 sway bar bushings
This part is OEM and a Quality Fit!!!!
If you are unsure of compatibility, please send us your VIN to verify application!!!!
https://www.stevewhiteparts.com/steve-white-catalog-11-19-dodge-challenger-1320-drag-racing-springs-and-sway-bar-kits-bushings-mopar-swm1320?parent=1032
2016 R/T Scat Pack
Doesn't the 1320 have adaptive suspension?
Interesting, will this fit a 2016 Scat Pack? I can PM you the VIN.
yes it will.....and yes they do
Luke
lower dont know,
if you buy a Challenger 1320 edition these are the springs and sway bars
Luke
2016 R/T Scat Pack
lower dont know,
Luke
I know, I guess I should have specified.
Do you have any specifics about the items in the kit? (Like the front sway bar being hollow)
Seems strange that the kit is parts from the 1320, but doesn't work with adaptive suspension, which the 1320 has, hence my confusion.
Discussion Starter #10 (Edited)
Now for the 1 million dollar question, will these negatively affect handling? In other words, would you run them on Big Red?
hell no, this is a drag racing set up, ill drag race you to the end of the 1/4 and when your braking, I'll turn >:)
if your looking for a drag race setup for not much money, this is it.....and pretty well thought out by FCA
for the autox and road racer, canyon carvers, totally different set up
Luke
Discussion Starter #12
bigger tires and bigger better brake system is also a must
Luke
2018 Challenger R/T Scat Pack
If I were to use just the 1320 springs but keep the normal Scat Pack sway bars would it handle decent for a daily driver but still add some weight transfer to the rear tires when launching?
Discussion Starter #17
i dont see why not, may reduce cornering ability but probably not significant
Luke
Any issues installing these springs in a 15 5.7 R/T? Super track pack
Discussion Starter #19
no, may not be lower, may sit higher
1 - 19 of 19 Posts
