1 - 4 of 4 Posts
I have a 2 post lift in my garage and am getting ready get in on the group Solo exhaust buy so it looks like I'll be putting my SRT up in the air for the first time. Looking under the car on the rear I see two rubber bumpers as a lift point. Up front there is a plastic cover under the rocker but no bumper. Do I use the subframe for a lift point? Normally I would go under the pinch welds but they are covered with the plastic ground effect stuff. Thanks.
With a lift use the two rubber bumpers you saw at the rear and the frame rails at the front. There are two holes in the frame rail at the area your lift arm should go.
Thanks Speedy. I'll be sure to look for the holes in the frame rail.
1 - 4 of 4 Posts
