1 - 4 of 4 Posts
I’m in the process of changing out the rear 6.5 speakers....do I need to get mounting rings to use the factory mounting holes? Also is there adapters for the speaker plugs so I don’t have to cut the factory wires?
Yes, and yes.
Go to Crutchfield DOT com and input your car info and pick a set of speakers for the rear deck. Add them to the cart and it will automatically add the adapters and wire adapters you would need. You can get the part numbers for those pieces that way if you want to buy locally, or you can just purchase them from Crutchfield if you cannot find them locally.
1 - 4 of 4 Posts
