1 - 2 of 2 Posts
Hello so I have a 2.75’ Borla Atak Catback on my 2017 Challenger RT I know the piping is the same as stock. My question is what size inlet do I need to add quad tips? I still have the same stock tips that comes on the Chally, do I need to get 2.75 or 3’? I see the stock tips go over the exhaust ?
2018 Hellcat. 2017 Scatpack.
it all depends on the demension of your actual exhaust pipe, but 2.75 inlet on the tip will not work if your pipes inside dia is also 2.75, if you want a slip fit. I would work if your butt welding them on. You'll need to actually measure your tail pipe outside dem.
1 - 2 of 2 Posts
