1 - 3 of 3 Posts
FYI too free flowing is not a good thing unless your motor is built significantly and needs it.
You can get a tune for the new setup and it would help you a little bit but like I said, unless you have a motor built to need the extra free flow, your low end torque will always suffer to a degree but you will gain a little bit of hp on the back end.
Are you actually sure that you lost a lot in performance and that's not just in your head? I went to all straight pipe and after a tune, didn't feel any real loss and the dyno didn't indicate anything really significant either.
I reset adaptives pulled fuse 31 did throttle recalibration she drives hard again. Powersticks are settling in and sound unbelievable!! They are a big attention grabber!!!
1 - 3 of 3 Posts
