1 - 10 of 10 Posts
going to be replacing the chrome grill surround with a black surround one, does anyone have any pointers or write-ups on the install?
I did a search and couldn't find much.... this is going on a 2017 challenger R/T scat..
thanks.
thanks.
Check out this thread...looks like the easiest way to remove those grille inserts is to pull the front bumper facia.
http://www.challengertalk.com/forums/showthread.php?t=636090
thanks XLRRR8.... wonder if anyone has any write-ups on the removal and install of the grill surround. i actually painted them matte blk which turned out pretty nice... but already having chips in the paint from road debris...
thanks guys... i did paint mine which turned out pretty good, its just the paint seems to chip easy, maybe it i put a clear coat over the paint that would help....
after reading up some, i may just leave it painted and do a clear coat over the grill surround to keep with chips...
some people say the install isnt bad some say it kinda sucks... lol
Attached is a PDF that might help and I've added another link that takes you to information on the Mopar.com website...both documents show how to remove the front clip to swap out grills. These should give you an idea of how to go about doing it. Some say it doesn't take more than 1/2 hour if you have another person there to help you remove the bumper clip. Others say it takes a while longer if it's your first time doing something like this.
Mopar.com Replacement Information
This video they remove the front clip
I tried the butter knife deal. It didn’t work. The tabs are a pain. Just pull the nose off and then you can snap the tabs off from the back. It is pretty much a one and done on them tabs anyway
Taking the nose off is about 30 min if you have done it before
So plan on a few hrs. But that is the right way to do it
thanks a lot A GUY that video was really good....... the install doesn't really look that bad.... I'm going to give it a shot.. thanks guys..
1 - 10 of 10 Posts
