Just got the call from the dealer. They found the Bank 2 oxygen sensor not fully seated and cross theaded. New parts ordered. Looks like it. Thanks for your input.If the Bank 2 oxygen sensor upstream of the catalytic converter has been replaced by the dealer and your PCM is still throwing a code, you should check the following:
1. Wiring problems (shorted, frayed wires)
2. Inlet air leaks or exhaust leaks.
