1 - 4 of 4 Posts
Drives fine smooth idle drives fine do not feel a difference noticed when I turned it off and got out I poped the hood and the car is off ots pinging like modt new cars the exhaust makes a noise but this was real rappid and when I started the car there was another noise I cant really describe everywhrre to get it diagnosed is closed so when I get off work ill see what the light says but any educated guesses
Have you tried reading the code using the key trick?
Without the engine started, cycle the key (on-acc-on-acc-on) fairly quickly and you should get a code on either your evic or mileage/trip display.
Did not know about that ill try it before I head to work
1 - 4 of 4 Posts
