1 - 11 of 11 Posts
Look what my dumbass did to my WB chin spoiler. Any suggestions on a method to repair it or should I look into sourcing a new one?
Buy a new OEM one from the dealer.
Agree, replace it with OEM part, or live with it until you really badly bang it up.
If you drive them, it's only a matter of time.
Since your chin spoiler isn't cracked, before you buy a new one, you may want to try improving its appearance by sanding.The procedure is similar to sanding a wood finish. Before sanding, clean off dirt and grime with a mild detergent solution. Use a 50/50 solution of vinegar (a weak acid) and water to smooth out the deep scratches and scuffs.
To avoid scratching, use silicon carbide or wet/dry sandpaper. It's usually black or gray. Immerse the paper in water for 10 minutes, then sand in a circular motion. Keep the sanding pattern irregular to avoid producing deep scratches that might remain visible. Using a foam block to support the sandpaper is helpful when sanding curved surfaces.
Run through the sanding grits in order from 220 to 400, 800, and 1,200-grit, finishing with 1,500 or 2,000-grit, depending on how smooth you want the surface. Clean the sanding residue with water after you're done with each grit.
If you desire a sheen, spread automotive clear-coat polishing compound on the surface and buff it with a lambs wool buffer.
Good luck.
2016 R/T Scat Pack
Good luck.
This.
Or honestly, no one is going to notice, and it won't be the last time to blemish it.
Dont make me upload pictures of my splitter
For a little damage like that, i dont thing its worth the time, hassle, and moolah to replace the whole dang splitter. Shes big, and low. Guarantee youll pick up a few more nicks here and there. Try the method posted above
I would use a dremel sandpaper disc to smooth out the damage, apply some JB Weld 50139 black plastic bonder using a popsicle stick to shape and then sand it smooth. After it dries spray some dupli-color black trim paint into a paper towel and apply to the repaired area. A few years ago a local body shop used this method on a scratched truck mirror and it turned out great.
2018 Hellcat. 2017 Scatpack.
they are by design, according to dodge, sorta disposable. cost isnt a lot, but replacement is a pita. If you are like me, that would always bother me, even "if" you were able to get the repair done so it wast as noticable. Id opt to simply replace it.
1 - 11 of 11 Posts
