Why are you wanting to keep the RPM's up. The 392 has a torque curve like a diesel. Actually going to a higher gear might help keep the tires under the car.It would seem a Circa 3.55 gear would wake this automatic up. Keep the rpms up in the power range.
Anyone gear it yet?
Kinda like Dodge claims the new SRT8 engine is 392 cid...FWIW, even though Dodge claims the 6 speed has a 3.92 gear, it's actually a 3.91, based on a physical inspection of the differential = 43 teeth ring gear and 11 teeth pinion.
Actually, Circa means "at, in, or of approximately".(Circa, means around)
"Actually"Actually, Circa means "at, in, or of approximately".
It can be considered analogous to "around". :browsmiley:
If you've never had a Mustang (I've had 4), or been around a Mustang "crowd", then disregard the comment. It's a Mustang "thing". Sorry."Actually"
Circa is (Latin) for around. Period!
So, at or in, fit in the foot print of the possibilities of circa. :browsmiley:
I do not know where mustang owner comes to mind, being dodge uses this gear and I have one installed, as do many Vipers.
