2020 Challenger Scat Pack F8 Green
We all know that these engines make a racket with upper valve noise on startup when they've been sitting a while. Mine seems too make the initial clacking sound after sitting only 10 minutes. Goes away in a few seconds. Brand new Scat oil is full. Is the oil filter drain back valve not working?
You might want to try swapping out the oil filter - easy to do and cheap item.
It could be the drain back valve in the filter doesn't seat correctly and doesn't provide the anti- drain back function as it should.
Reactions: Usmc1975
If it's not valve train noise you are hearing, it might be the active exhaust butterflies cycling. You can really hear them if you use remote start - first I get the fuel pump sound, then a nice "click clack" from the butterfly valves - then it's fun time. :)
2020 Challenger R/T Scat Pak
It might be this.....
My 2016 did this after installing a SRT oil filter. No valve chatter with the smaller filter. My 2020 R/T 50 (345) makes no valve noise at start-up. Stock filter.
