Mopar Fam and Fellow Challenger brothers & sisters. I'm hearing a clicking noise on both sides in the rear and slightly in the front when my wheel rotates under load. Before I get into this, let me inform you of the mods I have for the suspension and drivetrain. I have a staggered setup, 20x10.5 +20 on the rears with a 315 and 20x9 +15 with a 275 for the fronts. Have had the wheels for about a year now. The entire driver side suspension is new, this includes axle, knuckle, lower control arm for the spring, hub, and brand new AAD Performance Adjustable arms(installed a little over a month ago). For the passenger side, only the AAD arms are new everything else is from the factory. You may be wondering why one side is newer than the other, but that is a story for another day. I have Eibach lowering springs, Eibach front and rear sway bar, and G-Force Renegade Axles that I installed 6-7 months ago. I will also include that I have a tune from Jay Greene. The only things that I haven't touched yet are the factory differential and factory driveline.
Now that you know about all the setup, let me explain what has been going on since I installed the new AAD full-suspension arms. The arms are the most recent parts that I have installed in the car. When those got installed and went for a test drive and heard and faint click noise that I thought was coming from the front but upon further inspection discovered it was coming from the rear. Everything is tight and torque per AAD specs for each nut & bolt for each arm. Didn't think much of it at the time and just assumed that it was the arms settling. But as I have always been told, assuming really stands for making an ass out of you me, and that's where I made a mistake. Just last night while cruising around the click became clicking and was much louder than before. I will attach some video examples of this below.
I got the car up in the air and spun the front wheels to see if I could hear the clicking. No clicking forwards or backward. The next course of action I took was to check lug nuts. I put the stock wheels on with OEM nuts and rolled the car down the road. Heard the clicking, but a lot quieter. Put a brand new set of lugs on with the aftermarket wheels and the loud clicking was back and more consistent. I checked to see if there were any loose lines, hoses, or wiring that could possibly grab and/or snag that could also be the suspect but everything was good. So I know it will only click under full load and it's not my lugs, wheels, brakes (brand new set from 3 months ago), or arms. My next thought was it could either be studs or something with the driveline. After staying up for hours researching last night. I found that a lot of Mopar owners have issues with the carrier bearing on the driveline coming apart due to the heat of the exhaust and were making a similar noise, more of a hollowing than a click. But the consistency was the same. I haven't had the chance to inspect the driveline due to it being extremely late already and my brain already hurting lol. I talked to a buddy this morning and brought up maybe checking the u-joint on the stock driveline and see if it was worn. Going to be doing that the next time I have free time to get back under there.
It makes more sense in my head for it to be something with the driveline because of the loud clicking in the rear and faint click in the front rather than the axles themselves because of the quality and how newly installed they are.
This is already a long thread, but I wanted to be as detailed as possible so you guys could get the whole picture. If there is anybody that could give some advice on what the prime suspect could be that would be amazing. I have an event down in Vegas that I am going to in May and would like to have my baby down there with me. I think I have included everything, my brain is already starting to hurt again just thinking about it!
